Anti Vibration Coil Mount for Motoplat
MikBK77
Re: Anti Vibration Coil Mount for Motoplat
Post by MikBK77 »
I have run one of my Motoplat equipped SS20s without a key for a very long time and have never had an issue. It is hard to get the rotor positioned initially but I am now used to it. It has never moved once tightened.
I also have a Ducati ignition on a motor and it has proved to be exceptionally reliable.
Mike Best
Qld Vintage & Historic Karting
Australia
oldboyracer
Post by oldboyracer »
I tend to run my with a key, however there would appear to be a Hewland ignition key epidemic out there as I keep getting sent the wrong ones!
So I am going to run this without a key.
A good friend of mine has never ran any of his engines with a key, but there are a few things to remember.
Firstly, to lap the rotor onto the crank using engine grinding paste to remove any high spots etc.
Secondly make sure you have the Motoplat holder for when you come to tighten the crank nut.
You can use the sprocket holder to tighten it, but there has been a few issues with the crank twisting.
Best regards
Steve
Steve Strong
Steve Strong
JEB
Post by JEB »
Hi Steve,
I know you had your heart set on Clay, will I see you next weekend ? - I very much hope so - but it's a bit of a long treck ?
Roll on Rowrah 2013 :D :D :D
Garry Bracegirdle
